Fairlead bushings
  • Fairlead bushings
    Ordered a couple of new fairlead bushings from the factory, and where the originals were held in by a wire on each side, these ones are smooth. How do they attach? Are they ment to glued, and if so, with what?
    Thanks
    Ryan
    N43754
    Ryan Newell
    1946 BC12D NC43754
    1953 15A N23JW
    TF#897
    Re: Fairlead bushings
    Post a pic, I used cub style, had a little cuttin and welding to make them fit but they used a spiral ring to hold them in. Tim
      I''ll try do take a pic tonite or tomorrow. The old ones I have sound like you described, they have a wire ring on each end that hold them in place. The new ones that I recieved from the factory are smooth and are cut from a long tube into the smaller bushings, but there is nothing on each end to hold them in the welded on fairlead to the fuselage such as a larger lip or a cutin for a wire to go into.
      Ryan
      N43754
      Ryan Newell
      1946 BC12D NC43754
      1953 15A N23JW
      TF#897
        They are glued in with contact adhesive. The originals had a groove machined in them and held in with a snap ring.
        Winston Larison
        1006 Sealy st.
        Galveston TX, 77550
          Ryan,
          Chuck a bolt into a electric drill, and use the threads on the bolt to clamp the plastic sleeve. Put the drill in a vise and fire it up.
          I used a hacksaw blade (handheld) to cut my own grooves.
          Or glue it in.
          John 3728T
            There's a good thread on fairleads. Search "fairleads" and you'll find it. Bob Gustafson ("mulwyk") uses Piper and modifies them. Look for his posts. There are good ideas there. Many planes do not have fuselage fairleads, wrongly I'm sure, but they don't seem necessary and would be very hard to retrofit unless you're a midget, though the aileron cables do require them.
            Ed @ BTV VT
            TF 527
