Lyc. O-145-B2 ADs
  • Lyc. O-145-B2 ADs
    Are there any AD's on the O-145? I have looked all over the FAA site and Lycoming site, No luck.
    Mike Burnett
    1941 BL-65
    NC29815
    469-951-3433
    Re: Lyc. O-145-B2 ADs
    Mike,
    No there are none.You do want to make sure you adjust the valves as recommended and re-tourque the heads. Also,try to find an extra servicable set of heads and head gaskets just so you will have them later. As long as you maintain it and don't abuse it they are not too bad to give trouble but eventually you will have to replace head gaskets and maybe a head.....these items are not that expensive but very hard to find if you need them in a hurry.
      Hi Mike, Search 'head gaskets' here on the forum, good info on gasket availability. The last cylinder head I bought was $750. There is a fellow on this site that has access to pushrod tube seals. There are some service bulletins for these engines, though nothing earth shattering: SB 108 Sept. 5, 1944 - Magnaflux inspection of Lyc. O-145 and GO-145 Aircraft Engine Crankcases, SB 117 Jan 9, 1945 - Salvage of O-145 Heads with Stripped Spark Plug Holes by Installing 18MM Heli Coil Steel Inserts, SB 120 Feb 14, 1945 - Salvage of O-145 Heads with Stripped Spark Plug Holes by installing Spark Plug Bushing, Part No. 45399, SB 121A Apr 30, 1957 Replacement of Crankshaft Oil Seals, SB 123 Apr 25, 1945 - Bearing Crankshaft Front for O-145 and GO-145 Series Engines, SB 124 Aug 23, 1945 - Valve Seat Reconditioning Tools. These are all "how to" informational kinds of info. If you are interested in any of these I'll try to post them on this site or my gallery. Howard
      20442
      1939 BL/C
        Gents, Thanks. Howard, I will let you know if I need the SBs published.
        Mike Burnett
        1941 BL-65
        NC29815
        469-951-3433
          If you need new crankshafts we have lots of them. ( never needed one yet)
            Thank you Forrest. You are on the list.
            Mike Burnett
            1941 BL-65
            NC29815
            469-951-3433
              Howard, please post them for me. Thanks.
              Mike Burnett
              1941 BL-65
              NC29815
              469-951-3433
                Will do Mike.
                20442
                1939 BL/C
                  Thank you very much!
                  Mike Burnett
                  1941 BL-65
                  NC29815
                  469-951-3433
                    OK, the first batch are in my Gallery. Page 9. Will try to post the rest tonight. As far as I can tell the Lycoming manual and these SB's are not copyrighted. If anyone can show me that they are I will take them down. Anybody using the information posted should do a thorough check with an IA to make sure that the information is still valid, and not just a historic document of interest.
                    20442
                    1939 BL/C
                      They're all in the Gallery now.
                      20442
                      1939 BL/C
                        Howard, you mentioned that "There is a fellow on this site that has access to pushrod tube seals.". I searched and did not find any threads related to that. Do you know who it is? Thanks.
                        Bob Waldron
                        1940 BL-65
                        Webster Sky Harbor airpark, MN
                        Bob Waldron
                        1940 Taylorcraft BL-65
                        SkyHarbor airpark Webster, MN
                          Bob, Check your PM's.
                          20442
                          1939 BL/C
