In rc gas powered RC helicopters we use small brushless motors connected to the engine crankshaft to generate power so small on board receiver battery packs can be used and flight time is limited only by fuel.
the entire setup with motor and rectifier/regulator is about 4 oz. Good for up to 7 volts and 10 amps.
so, I got to thinking... Instead of using the MAMMOTH original wind generators why not use a small brushless motor with a prop (maybe a 9x6) connected to a recitifier/regulator? With the proper motor and propped correctly It would be a simple task to get 14 volts and as much as 15 amps or more. Weight would be a whopping 6 ounces plus whatever it would take to mount it.
here's what we use in gas helicopters
can something like this be approved by he FAA to use in a Tcraft?????
Tom
