Is there a standard to go by when using the term 'sealed' as in 'sealed' strut? - MikeH
Please define 'sealed'
Re: Please define 'sealed'
Consider this; Will the strut interior volume hold pressure? If yes and its coated on the inside with a preservative then its "sealed"Originally posted by mhorowit View PostIs there a standard to go by when using the term 'sealed' as in 'sealed' strut? - MikeH
In other words imagine that you drilled and tapped a hole in it and installed an air hose fitting and hooked it up to an air hose. Would it hold pressure or leak. Kinda like a gas tank leak test or a radiator leak test.
Like the earlier thread explaining that acrobatic a/c presurize the tubing and watch a gauge to insure they don't have a crack. However, that doesn't define 'sealed' as in "what if I get a good bill of health for my strut, then coat the inside withOriginally posted by drude View PostConsider this; Will the strut interior volume hold pressure? If yes and its coated on the inside with a preservative then its "sealed"
Davethen weld the drain hole shut do I now have an acceptably 'sealed' strut? - MikeH Mike Horowitz
There are more holes to close than the "drain" but if they were all closed I should think that is sufficient.Originally posted by mhorowit View PostLike the earlier thread explaining that acrobatic a/c presurize the tubing and watch a gauge to insure they don't have a crack. However, that doesn't define 'sealed' as in "what if I get a good bill of health for my strut, then coat the inside withthen weld the drain hole shut do I now have an acceptably 'sealed' strut? - MikeH
Make that suggestion to Andy McAnual and on the docket.
A proposal for keeping your good old struts in service
Certainly. Please see my proposal at http://members.cox.net/mhorowit/Originally posted by drude View PostMake that suggestion to Andy McAnual and on the docket.
Any comments greatly appreciated.After a couple days I'll post it to the FAA - MikeHMike Horowitz
Somehow, from somewhere in the past (Piper strut AD??) I was under the impression that the strut was purged with an inert gas before sealing, to get rid of any possible oxygen that could propagate corrosion... I don't remember who told me that one...
I think there's a bit more to it than just welding up the holes, but it's going to be interesting to see what the FAA says.
JHI'm so far behind, I think I'm ahead
JH - I know it's risky quoting as gospel something someone said on the Inet, but wasn't there an earlier thread that proposed that the linseed oil had some effect on the trapped air in the now sealed tube? That would have to be validated before it bacame a usable fact, but it's a potential lead- MikeHOriginally posted by N96337 View PostSomehow, from somewhere in the past (Piper strut AD??) I was under the impression that the strut was purged with an inert gas before sealing, to get rid of any possible oxygen that could propagate corrosion... I don't remember who told me that one...
JHMike Horowitz
