Is there a standard to go by when using the term 'sealed' as in 'sealed' strut? - MikeH
Please define 'sealed'
Re: Please define 'sealed'
Originally posted by mhorowit View PostIs there a standard to go by when using the term 'sealed' as in 'sealed' strut? - MikeH
In other words imagine that you drilled and tapped a hole in it and installed an air hose fitting and hooked it up to an air hose. Would it hold pressure or leak. Kinda like a gas tank leak test or a radiator leak test.
Originally posted by drude View PostConsider this; Will the strut interior volume hold pressure? If yes and its coated on the inside with a preservative then its "sealed"
Davethen weld the drain hole shut do I now have an acceptably 'sealed' strut? - MikeH Mike Horowitz
Originally posted by mhorowit View PostLike the earlier thread explaining that acrobatic a/c presurize the tubing and watch a gauge to insure they don't have a crack. However, that doesn't define 'sealed' as in "what if I get a good bill of health for my strut, then coat the inside withthen weld the drain hole shut do I now have an acceptably 'sealed' strut? - MikeH
Make that suggestion to Andy McAnual and on the docket.
A proposal for keeping your good old struts in service
Originally posted by drude View PostMake that suggestion to Andy McAnual and on the docket.
Any comments greatly appreciated.After a couple days I'll post it to the FAA - MikeHMike Horowitz
Somehow, from somewhere in the past (Piper strut AD??) I was under the impression that the strut was purged with an inert gas before sealing, to get rid of any possible oxygen that could propagate corrosion... I don't remember who told me that one...
I think there's a bit more to it than just welding up the holes, but it's going to be interesting to see what the FAA says.
JHI'm so far behind, I think I'm ahead
Originally posted by N96337 View PostSomehow, from somewhere in the past (Piper strut AD??) I was under the impression that the strut was purged with an inert gas before sealing, to get rid of any possible oxygen that could propagate corrosion... I don't remember who told me that one...
JHMike Horowitz
