Re: Fuselage strut fitting - FAA Airworthiness Concern Sheet (merged)
Does that mean that we have to remove the gear to inspect the fitting? Also, can the fitting be inspected with the strruts in place or miust the struts be removed from the fitting to inspect it.
Frank
Frank
with the factory , FAA and others. Do what it says in the SB, maybe you all can help if you add, owner, A&P, IA to your signature, THIS will NOT be prevenative maintenance. enough said without violating confidences...
