Strut Airworthiness Directive (AD) (merged VI)
    Re: Strut Airworthiness Directive (AD)
    Andy & I are in official contact, I totally agree that the tracing of these struts are vital. Kind of like Rotor blades on my other machines.
    Time, usage, storage, all are a factor. It still boils down to Common Sense , how to teach it to the owners and the mechanics is the question. If it appears rotten it may be rotten !
    Yes I ferried a ship into here one time that had been sitting on a limestone floor , wet at times for 5-7 years. Paint was good, metal was rotten on the struts, tail surfaces. lower fuselage longerons, etc. WE scrapped the bad parts. We have people trading stuff like that off to other folks and that is the bad part.
    I will be pushing the non-destructive testing lab north of me for some answers today & tomorrow.
    I was of the opinion that the press test with the Maule and the ring test with a punch was the best & most economical , I am still looking into it all.
    I do have an open mind, I fly aerobatics with these struts , +4 g's & -1.5 many times........
      Hi guys, a few years ago I went to do my annual and when we got to the bottom of the lift struts I was able to push my finger nail through the bottom. I had been flying that plane for almost a year and pulling 6gs at times when loaded at gross.
      I still think that the punch test is a good way to see if there is enough rust to justify a loss of strength.
      Cracking on the other hand is much harder to see. This is not a part that is subject to lots of high stress vibration or over bending.
      I can understand that the FAA would like to have some hard data showing that the 60 year old struts are safe. But in my opinion, after an NDT test to look for cracking, we should just be able to do a punch test for the next 8 years.
      And by the way, when is the FAA going to wash there hands of us and give us the “Owner Maint.” option.
        I have cut open the cap off struts before, but finding a competent welder will be about like finding a NDT guy in certain areas. It will also require repaint of the strut fromt the welding. I also beleive in the Piper AD you have to remove the paint from the area of inspection if I remember correctly. I frimly believe also the Maule tester method should be included and will be sending my comments to the FAA regarding it.
        Yes there will be struts found with corrosion. It is inevitable. To say this won't have an adverse economic impact in the AD is incorrect considering strut replacement will cost up to 15%-20% of the value of some aircraft, and may ground many owners.
        Drude: I doubt you will find very many used struts laying around that are any good. I am always on the look out for good used struts and they are just not out there.
          my point exactly. If todays mechanics today were taught that tube and fabric airplanes still exist, they would be able to do a proper inspection and find these issues and correct them. Sometimes I almost wonder if we need a seperate ticket like the big iron boys get today.
            What separate ticket do big iron boys get? Never heard of one other than an Airframe or Powerplant.... (Not saying there isn't one, I am curious)
              About 5-6 years ago, they changed the mechanics ticket over to AMT(Aircraft Maintenace Technition). If you got your ticket under this new system, you were not able to work on anything over 12,500 gross until you received a transport mechanics rating making the mechanic an AMTT. Anyone under the old system was grandafthered in. They may have changed it again, but that was how it was when I was still studying the regs to get my IA.
                I spoke with Mr. Mcanaul (the FAA engineer and "A.D. author") regarding the Maule punch test. He personally does not think it is adquate. Supposedy they performed tests on corroded struts with the Maule tester and they passed. I guess his opinion of what is acceptable and what isn't is different than mine. That's the way it goes.
                I guess I will be looking for a NDT company to send my struts to.
                Winston
                Winston Larison
                1006 Sealy st.
                Galveston TX, 77550
                  Why can't the test be done with the struts on the aircraft? What is the chance the AD can be modified to not have to pull the struts to comply?
                  Danny Deger
                    I'm not sure I didn't discuss that issue with him. It does seem that it would be possible to do them in place. Except the bottom end plate.
                    Winston Larison
                    1006 Sealy st.
                    Galveston TX, 77550
                      In reading the AD, are we good until the 20th and then for 5 hours
                      after that.
                      L Fries
                      N96718
                      TF#110
                        I agree with the question. What is it that we are required to do?
                        I am ready to start my annual inspection. I have read the AD and am confused, and more so after reading these recent posts. Can someone please explain it in plain English? How about a brief explanation so that I can discuss it with my mechanic...
                        Thank you
                        Jack D
                        N44057
                        • #27
                          You need a visual inspection performed within the next five hours after August 20th. If you installed new unsealed struts you have 24 months from the date of installation to perform the NDT inspection. If they are older struts or original struts you need the NDT inspection within three months after August 20th. Then you need the NDT inspection every 24 months from now on unless you install sealed struts.
                          That is my understanding, tell me if I am wrong.
                          Winston Larison
                          1006 Sealy st.
                          Galveston TX, 77550
                          • #28
                            Danny Deger
                            Because they want you/mechanic to detect debris inside the strut (if it exists) is my guess.
                            • #29
                              Also so the bottom plate can be inspected is my guess.
                              Winston Larison
                              1006 Sealy st.
                              Galveston TX, 77550
                              • #30
                                yeah, good point and also see inside the attach fitting on the fuselage
