Does anyone know what the correct orientation of the mag drive gear to distributor gear is? The drive gear has a notch on one internal tooth, and the distributor gear has a notch for the timing pin on the cover. I would expect to see a mark on the distributor gear between 2 gear teeth, but there are only a few radial marks on this phenolic gear.
Any help would be greatly appreciated.
thanks,
thanks,
