gar-aero
  • gar-aero
    i saw a tcraft with 850-10 gar-aero he left so fast i did'nt get to chat it makes sence a tire that is abought the same size as good year tundra but has a wide foot print there a cub on the field with gar-aero there 17years old makes me want to try them marc n43643
    Re: gar-aero
    Bushwheels has an STC'd 26" tire now, that weighs the same as an 8.50... at least that's what they told me..... I'm gonna sell a set of 31's and get some!
    JH
      Re: gar-aero
      That's awesome! Here's the page from Bushwheel's website reflecting the STC: Bushwheels STC
      It does state that you "must have heavy duty brakes". I wonder specifically what that means. It could be a problem, as I'm unaware of any STC'd brake upgrades. Maybe stronger cables or proof of weekly squats would do the trick!
      Vincent
        Re: gar-aero
        howdy jh,i saw the 26 bush wheels but after the way alaska bush wheel treated my buddy i will think twice before i do any work with them the gar-areo will last a lot longer then bush wheel my buddy bought a set of 26 last week i will watch the tire to see how they work maybe they have fix the problem time will tell.marc n43643
          Re: gar-aero
          Marc,
          I've dealt with Gar Aero for years (when Gary Stevenson owned it) and always had great luck...understand he's sold out, and the new people are great to deal with too.... So far, my dealings with ABW have been great, and the tires really aren't comparable, as they're designed to do two different things... Sorry to hear your friend had a bad experience!
            Re: gar-aero
            thanks john to here that right now i cant worry to much abought the tires now called my my faa insepector im working on trying to do the convertion from shinn th 150 have you heard of any getting thin field approved marc n43643 ps not going experimental too hard and too much bs
              Re: gar-aero
              Floats Alaska have the Gar Aero product line, and some out there think that the bush wheels are so great, a local cub driver up here get a stick through them and ground looped it bad...the Gar Aeros are cheaper and can handle much more abuse. Even though they are not STC'd, you an get a field approval ......thier tail wheel conversion is only 600.00 and the bushwheel is like a grand or so. So that is my 2 cents worth. I think that the 26" goodyears would be a cheaper option, but this is coming from a guy that is running 8.50's Well best of Luck Tim
