Ari Pressure for 8x6 tire?
  • Ari Pressure for 8x6 tire?
    What is the recommended tire pressure for an 8x6 tire on a T-craft?
    Danny Deger
    Re: Ari Pressure for 8x6 tire?
    I believe it is 20 psi, I usually keep my tires just under that, 18ish or so...
      Hi Danny,
      The search tool is handy to find previous discussions. For example, look at
      Dan Brown
      1940 BC-65 N26625
      TF #779
      Annapolis, MD
        Danny,
        I usually kept the 8:00's on my F21B around 18-19psi. Worked for me.
        Craig Helm
        Prior owner N8ZU '90 F21B
        KRPH
          I run 8-12 psi in my 8.50's, I have to be careful that I dont shear off the valve stem though. They sure land softly with the lower pressures. Good luck Tim
            I always run 15-18psi. As stated by Tim,anything under 15psi you run a much greater risk of shearing the valve stem.
