Valve Cover
  • Valve Cover
    I pulled my nose bowl this morning to look for my oil leak. I found it. Someone had put a screw that is too long in a cowl cover fitting. The screw had rubbed a small hole in the valve cover. Let this be a lesson to use the right length fastener.
    In the mean time I need a valve cover for a C-85-8 engine. Anybody got one they want to sell?
    Danny Deger
    Re: Valve Cover
    If its a small hole from the point of a screw why not remove the cover, weld the hole closed file it down nice, paint and reinstall.
      Re: Valve Cover
      Or you can solder it !
        Re: Valve Cover
        You can always find them on ebay for $20-40 bucks for a set of four.Just go to ebaymotors.com ,aviation parts, then continental....search until you find them. Or do a search for continental valve or rocker covers
          Re: Valve Cover
          I've got a bunch of them. I'll send you one for $5.00 plus shipping that I guess will be about $3.00. So if $8.00 is ok, let me know. I'll send it out monday. I have your address I think.
          Ed@BTV VT
          TF 527
            Re: Valve Cover
            Ed@BTV VT
            TF 527
            Thanks for the offer, but I bought a new one from Fresno. I spent more money, but I am getting the part in time to go flying over Memorial Day weekend.
            Danny Deger
              Re: Valve Cover
              I just got my new valve cover in -- unpainted. Anybody know a place to mail order a can of spray paint from? I have the standard Continental "tanish/gold" color.
              How about primer? I assume I need to prime the cover before I paint it.
              Danny Deger
                Re: Valve Cover
                Danny,
                Go down to your local paint supplier and have them mix you a pint of high temp paint using one of your old ones to match it by.
                  Re: Valve Cover
                  Danny,
                  I found a spray can at a local shop called "The Aviator Shop", I thought they just had sectionals, magazines, and hand held electronics. Turns out they have a large collection of fastners, paint, etc. I am having the fastner that caused the hole in the valve cover moved 1 inch today. I might be flying by sunset tonight
                  Danny Deger
                    Re: Valve Cover
                    Update on my plane. The valve cover is on, I set the idle back down today, the brakes work great, I moved the fastner that caused the valve cover damage down an inch, and I cleaned all of the crude out from under the floor boards (and got some nice tools :-).
                    All I need to do now is put the cowl back together -- and fly, fly, fly!!!!
                    Danny Deger
