Why sloped ends?
  • Why sloped ends?
    The aileron spar has a reinforcement plate in it's center and it has sloped ends.
    See attachment. Any idea why the ends are sloped? how critical do you think that slope is? - Mike
    Re: Why sloped ends?
    I susoect the slope follows the airfoil contour. It may be a clearance issue when the aileron swings upward as well as a leading edge fit issue.
      My guess is that if it slopes longitutinaly it is there for stress relief Dick
      TF #10
        I could use some stress relief. - MikeH
          Mike,
          In a word..... "elegance"
          Since you're having fun working in wood, you might enjoy my friend Stephan's articles about building a Falco.
          Jim
            arg... I was thinking of the top and bottom but you were asking about the inboard and outboard end, sorry, my bad, answered wrong question.
            I think its a shrinkage and stress issue.
            Check out ac43.13-1b chap. 1 section 1.2, that may help.
            Actually keep going into the other sections in chap. 1 it comes up many times.
              Could be a build in lightness technique. The part of the wood that has been removed probably didn't carry very much of the stress.
              20442
              1939 BL/C
                Hey Howard! Was out your way Friday - took my ribs for cleaning, alodining and priming. Talked to Dave and seemed to be a nice guy. Looking forward to working with him. thanks for the suggestion - MikeH
                  Stress was a correct answer but it is probably better addressed as a "load spreading" device/design/technique. Don't want to go directly from reinforcement to non-reinforcement in zero length.
                  No doubt elegance does have something to do with it also. It would be ugly the other way.
                  Bet you will see similar stuff if you look in AC43-13 woodworking section.
                  Darryl
                    ANC-18 and ANC-19 if you want to delve deeper into the heart (wood) of the matter.
                    Essco Aircraft sells Aircraft Manuals and Pilot Supplies at wholesale prices. We specialize in hard to find Aircraft Manuals and Vintage Aviation Videos. Essco Aircraft stocks Pilot Operating Handbooks (POHs, Pilot Information Manuals (PIMs) Aircraft Owners and operators Manuals. We are the Aircraft Manual People.
                      Mike, Dave is a good guy, he did the annual on the 172 and found an AD that had been overlooked by several IA's for many years! Call me next time you are in the area, maybe we can get lunch. H
                      20442
                      1939 BL/C
                        Howard,
                        Where are you in Maryland?
                        John 3728T
                          John, I'm in New Market. 10 minutes East of Frederick. The T-craft is based up at Keymar.
                          20442
                          1939 BL/C
                            FlyGuy is correct. The short answer is "to avoid abrupt changes in cross sectional area." Otherwise, when you flex the member it'll have a stress point right at the edge of the reinforcing plate and break there every time.
                            Didn't Stephan Wilkinson write about the Falco in some magazine many years back? I seem to remember following that project with envy from conception to the point he sold the plane...
                            New Yoke hub covers
                            www.skyportservices.net
                              Hi John,
                              "Air and Space" http://www.seqair.com/Hangar/Wilkins...MovingDay.html
                              More here....scroll down. http://www.seqair.com/Hangar/Wilkinson/Wilkinson.html
                              Also.... http://www.amazon.com/Gold-Plated-Po.../dp/1592282563
                              And.... http://www.amazon.com/Man-Machine-Be.../dp/159228812X
                              Happy reading!
                              Jim
