I've been away--wondering where the SB on lift struts has gone, and what the latest information is. Forrest was going to post some info when he got back from Sun n' Fun
Lift Strut Service Bulletin
Re: Lift Strut Service Bulletin
I am back! checking today .Taylorcraft Foundation, Inc
[email protected]
When does this take effect? I've received nothing from the factory or the FAA. I can assure you there won't be anyone in close proximity to me set up to do eddy current tests or ultrasonic tests......I heard mention of a borescope.....what are everyones thoughts on this?....can you share you expertise with us laymen....If we are writting to the FAA.....what do we suggest as alternatives? You A&P's and IA's give us something to hang our hat on. Please. I have 4 T-crafts....could be EXPENSIVE for me....I'm willing to do something that makes sense...but the Service Bulletin is worded to promote factory new struts to eliminate bi-annual inspections.....
Originally posted by Dano"T" View PostWhen does this take effect? I've received nothing from the factory or the FAA. I can assure you there won't be anyone in close proximity to me set up to do eddy current tests or ultrasonic tests......I heard mention of a borescope.....what are everyones thoughts on this?....can you share you expertise with us laymen....If we are writting to the FAA.....what do we suggest as alternatives? You A&P's and IA's give us something to hang our hat on. Please. I have 4 T-crafts....could be EXPENSIVE for me....I'm willing to do something that makes sense...but the Service Bulletin is worded to promote factory new struts to eliminate bi-annual inspections.....
Originally posted by Dano"T" View PostI see.....so the little blurb on the top right corners says: Taylorcraft CONSIDERS complience manditory.....key word ConsidersTaylorcraft : Making Better Aviators for 75 Years... and Counting
Originally posted by VictorBravo View PostI hate to be a fly in the ointment, but REGARDLESS of who or why it happened, it might be a good idea to do a good basic inspection. The Piper ice-pick test, or a mbile X-ray test or something would not hurt in terms of 60 year old airplanes.)There are a variety of ways to ensure that the strut is sound. If one doesn't have access to the particular type of non-destructive testing referenced in the service bulletin and chooses to use some other means of creating confidence in the integrity of the aircraft I was just pointing out that a issuance of a service bulletin doesn't necessarily need to change their vacation plans or cancel the down payment on the new house. And 60 years certainly is a long time for a piece of steel to be in service... The results of a structural failure would be catastophic under nearly any scenario so let's keep looking these aircraft over thoroughly so we can find out about maintenance concerns on this forum and not out of the newspaper.
I did a search on the FAA service difficulty reports website. Only one report had anything to do with struts and it was about the jury strut adjust threads.
I heard an unsubstantiatiated rumor through an FAA source that the hubub is about a wing-fold incident or crash that was reported. Does anyone have any knowledge of this?
Certainly these old airplanes need to be inspected for this. But is an AD warranted? We all need to be researching and asking our FAA folks to update us.Terry Bowden, formerly TF # 351
[email protected]
UNIVAIR STRUTS - For whatever it is worth... my father-in law's BC65 has univair wing struts. They seem to be well made, and heavier than the original BC65 struts. The one on the right side continually seeps linseed oil. Keeps the step kinda sticky... hard to clean. But this gives me a warm fuzzy that there is plenty of corrosion inhibitor.Terry Bowden, formerly TF # 351
[email protected]
Originally posted by barnstmr View PostI did a search on the FAA service difficulty reports website. Only one report had anything to do with struts and it was about the jury strut adjust threads.
I have searched here. Almost all of the accidents were ground control issues or pilot error/bad decision. I have found nothing related to wing strut failure.Terry Bowden, formerly TF # 351
[email protected]
[email protected]
