Brake cable
  • Brake cable
    Anyone out there have an extra brake cable for manual heel brakes or know of where I can purchase for my F-19?
    Re: Brake cable
    You can use any aircraft grade 1/8" cable, you will know it because it has colored threads woven in it. Spruce, Wicks, etc. will have it. Good luck Tim
      Re: Brake cable
      Does the F-19 use 1/8" ???? The BC12D uses 1/16" which is a little light in my opinion but that was standard,I used 3/32" and it works great. If you use 1/8" in a BC12D then you will not have very good brakes because you can't get them tight enough and they are also very,very stiff.
