New axle for F-19
  • New axle for F-19
    I"m rebuilding my 75' F-19 and in having a nearby shop magnaflux my axle's found one is cracked and needs a new one welded on. Anyone know who might have one and a jig and can do the work? Thanks Jack
    Jack, I split this from the "wheel jack" thread to make it more obvious. Rob
    jack
    Re: New axle for F-19
    "Bump" to get some attention (split from the "wheel jack" thread)
      Where is the crack at on the axle ? I've got some F-19 gear legs around here and the axles may be good I don't know, sounds like you are going to have to cut the axle off the legs and weld on a new one. You may have to build a jig.
      Wolf Lake Aircraft Services
        I also need to find a complete left gear leg assy with the inch and a half axle
        Lance Wasilla AK
          The crack is right where the axle welds on to the flat circular plate that is welded to the gear cluster. Roger on the jig. I have found one shop in the N.M. area that tells me they can do it if I can get them a new piece of stock.
          jack
            howdy all ,wlas how much for the gear and and what do i need to do to fit bcs12-d need that straght axel.marc n43643
