I have a glass Tillotson gascalator in my plane. at the last annual we replaced the valve and the gaskets. However at the first flight of the day after turning on the gas and draining it the thing continues to drip. After things warm up it seems to be ok. Yesterday we discovered that the leak is actually at the top. There is a bolt that goes through a bracket on the engine mount into the top and there are a number of spacer washers under the bolt. The leak is getting past the bolt threads and out the top. I put permatex on the bolt and that seemed to seal things up but the entire mounting situation doesn't look right to me. When I looked at a friends T-Craft there appeared to be a fitting on top of the gascalator that had a line coming from it. Is this to the primer? My primer started leaking so I told my mechanic to remove it as I always do fine without it. I'm just wondering if this is how he removed it and essentially "jipped out" the the primer fitting by putting in spacer washers. This is beginning to make sense now since I could not figure out why the bolt threads at the top of the gascalator went right into the gas supply and was not sealed at the bottom.
In any case I want to get rid of the entire thing and get a new gascalator as I'm tired of dealing with this.
I just want to get the best unit out there and put it in and be done with all this aggravation. Any ideas would be appreciated.
Thanks!!
Thanks!!
