Wing Spars
  • Wing Spars
    Hey guys,
    Using the forum for the first time. I'm restoring my 46 and have some ?'s. I'm sure they have been asked before. I need a data plate for it ( New repo ). Also need to replace the wing spars ( rat nests in the wings for thirty years) were can I get them Pre cut and drilled? Or do I have to make them myself?
    Thanks
    Eric Miller
    Project Warbird
    Salvage / Museum
    1946 BC-12-D N44464
    Re: Wing Spars
    Try Univair for pre made.
      Re: Wing Spars
      Eric,
      There's a blank data plate on ebay right now: click here
      Aircraft Spruce is well regarded when it comes to.......aircraft spruce. They are the standard source for spars.
      regards,
      Vincent
        Re: Wing Spars
        Thanks for the info guys. I'm watching the data plate and will order the Univair catalog. I need to buy a new windshield. What is the best tint to get? The green, grey, or clear.
        Thanks
        Eric
          Re: Wing Spars
          Our data plates are $10.00 ( original) I do have to fill them out here.
          That is another $40.00..... Join the Foundation my friend and find out we have two sources for spars... Univiar is the best right now.
            Re: Wing Spars
            I know that Buzz Wagoner quoted me on spars, they were spendy, they will predrill them though. Good luck Tim
              Re: Wing Spars
              Forrest,
              I will join the foundation and get the data plate from you. I will send out the info and check next week.
              Thanks
              Eric
                Re: Wing Spars
                Forrest
                That plate sold for $130 bucks on Ebay
                B 52 Norm
                1946 BC12-D1 Nc 44496
                Quicksilver AMPIB, N4NH
                AOPA 11996 EAA 32643
                NRA4734945
                  Re: Wing Spars
                  Yeah and that was the second one in a month!!
                    Re: Wing Spars
                    Are we in the wrong business Kev?
                    B 52 Norm
                    NRA4734945
                      Re: Wing Spars
                      Norm I think we should be boot legging data tags for t-crafts and j-3's. Looks like they're worth a small farm in Georga.
                        Re: Wing Spars
                        Someone asked to make a copy of my data plate, said he would give me $50 dollars to use it for one hour, and it went to Guam???? I think that is where the $130 plate came from, he is an airline pilot and goes lots of places and buys lots of stuff and it all ends up on ebay, O.T.
                          Re: Wing Spars
                          OK I tried to get a quote from Aircraft Spruce, they said they do not have wood in the right size for my 41 BC. So will go to Univair next. However how do you get all the nails out of the ribs with out deforming the ribs terribly? Or do you just get them off and straighten the ribs when done. I have everything else off but the ribs. Let them go till last.
                          Larry
                            Re: Wing Spars
                            Hi Larry:
                            I worked a putty knife under the rib flange just enough to move the old nail head up 1/16 inch or so. Then I grabbed the nail with a small dykes (wire cutter) and rocking the tool handles down (cutter end up) will pull the little SOB right out without damaging the rib. The rib flange will have a bit of a wave to it, but don't worry, when you nail it onto the new spar it'll lay right down happy as a pig in shit.
                            Bob Gustafson
                            NC43913
                            TF#565
                              Re: Wing Spars
                              Originally posted by mulwyk View Post
                              when you nail it
                              Bob - did you make any effort to close the old nail holes in your ribs prior to renailing them in place? - Mike
