HI everyone:
February here in New Jersey was awful. My plane wound up sitting since the end of January and I just flew it for the first time today. At runup the left mag was rough and had about a 150-200 rpm drop. I figured the bottom plugs may have fowled and that a short flight in the local area would clear things up. Well, I flew around for over an hour and the situation really didn't improve. The points were changed 21 hours ago and it was running fine the last time I flew it. We checked the bottom plug wires and all looks fine. I didn't pull the plugs since I didn't have the tools with me today but I'm planning on doing it next week. Whatever is wrong went wrong while it was sitting. Its definitely not an internal engine problem because it runs great on the other mag. Any ideas??
Thanks!
Thanks!
ops:
) and finding the bad could be done with the cowling off. Installed a set of new plugs on 20442 this year and about every hour one would fail! no obvious faults, internal shorting??? Those failures would give a 150-200 rpm drop. To find the culprit I would have the TAIL TIED DOWN, warm it up and let it idle, always holding on to the front strut with one hand put my other hand behind the exhaust outlet and feel the exhaust pulses, looking for a ragged pattern. On the Lyc. with dual exhausts this would narrow it down to two cylinders. then knowing which mag is low follow each of that mags wires out to it's plug. With the engine still at low idle take a long insulated handle screwdriver and short each suspected plug to ground, cylinder, exhaust pipe, whatever's close. When you hit a good plug the engine will falter noticably. When you ground the bad plug the engine rythym will not change. You found it! On the Continentals with the cross over exhaust you'll have to follow four wires out to their plugs from the low mag.
