Re: Adding turn and bank
"It actually corrects for (mostly imperceptible) interference caused to all radio signals passing through the "weather" in the ionosphere - that's it's purpose."
Actually the main purpose of WAAS is to monitor known ground positions and compare them to where the GPS says they are and then send back a corrective signal that tells your GPS "you are not really there, you are really here." If it corrects for other things that is good, but not it's main purpose.
My 129 dollar Magellan has it, WOW, and will give me the same indication on the number 2 of runway 32 within two feet for months after I put a user waypoint there.
You know, I can practice for days with a ball compass and two weeks later it is still confusing to use it under difficult conditions. My brain just has a resistance to the way it works even though I have actually sat down and designed one that reverses the direction of operation.
This has turned into an interesting thread, hadn't thought about minimum, minimum instruments to survive in accidental IFR before.
howard
