Need Prop Bolts
    Re: Need Prop Bolts
    Originally posted by NY86 View Post
    A McCauley 1A90 or 1B90 on a flanged shaft with a skullcap uses AN6H-31A bolts. Use AN960-616 washers on the 4 without the skull cap bracket and AN960-616L on the other 2.
    I am trying to mount a Sensenich 76AK-2 metal prop on a tapered shaft C85 in my BC12-D. I don't have the old prop bolts from when I took it apart years ago. I am not using a crush plate. I have the skull cap spinner bracket to consider (mounts under the nuts on two of the prop bolts). I am having a hard time finding the right size bolts. I have bolts from Sensenich, but they appear to be too long. I have new Sensenich bushings for the install (insert into the back of the propeller). Been searching the forum and found this string. John, do you know the specific bolt / washer combination for my situation?
    Thanks, Rod
      Re: Need Prop Bolts
      Should be the same as a McCauley prop; the hub thickness is the same. I'm going from memory here, but I think you need AN6-33A bolts. Use AN960-616L washers where the skull cap bracket goes.
      New Yoke hub covers
      www.skyportservices.net
        Re: Need Prop Bolts
        Thanks John, I got the bolts and washer I needed today. I had a new bolt kit for a McCauley and they worked out just right.
        Rod
