Hello everyone!! i am a new member to the tribe although i hve been lurking
awhile. My BC12D has a Flottrop wooden prop 72X48. it seems poorly
made as the metal leading edge sticks up from the wood of the propeller.
My cruise is lower than i would like at around 87mph gps verified 2 directions at 2150rpm.
I am considering going to a Sensenich metal prop 74X48, do any of you have
experience with either of these props?
what kind of improvement should i expect on 65 hp?
thanks, Fred
thanks, Fred
shorten it. Experience has taught me that with a cruise prop it is not recommended to maintain extended climbs at VX or even VY, Instead you should use a cruise climb or step climb to keep from overheating the engine when trying to put a lot of airspace between you and the surface. The Tcraft responds well to aerodynamic cleanup, and weight reduction in regards to increasing speed.
