Experimental or E-LSA????
  • mulwyk
    replied
    Re: Experimental or E-LSA????
    OK Sabrina, I'll bite. Was there really a combat BL65 dropping grenades in Palestine? Sounds like something from the first days of WWI.
    Bob Gustafson
  • taylorcraftbc65
    replied
    Thanks for the info guys. The fuselage that I have had four tubes cut out of it to restore another Taylorcraft. I can't find a serial number anywhere, and seeing as I taught "Tee" how to gas weld by replacing the missing tubes, this one is going to be an experimental "replica" of the BL65 that dropped hand grenades on a palistinian war camp during the first war of independance after WW II.
  • cpirrmann
    replied
    Originally posted by Bobdog View Post
    I agree with you. the FAA says the the plane can be built from "spare parts" which is exactly what my plane is. I also think that there is a strong argument for being able to convert from standard to experimental after a complete restoration, if the owner desires to,.....the only problem here is the fact that the plane was a previously licenced plane. Forest probably has more insight on this.
    I think you're right about the problem. I got info from EAA and making a licensed, certified experimental appears just for that. To experiment with for a specific purpose at a specific place. Not like an experimental homebuilt. It'd seem to be better to reverse engineer a T craft and build one from scratch, witha different engine, etc, or whatever. Hmmm..... maybe I better get some tubing and try some of Forrest's ideas.
  • Bobdog
    replied
  • mulwyk
    replied
    An experimental T-craft. That certainly sounds like an excellant idea for many situations. And it would greatly reduce the cost of ownership. Please keep us posted on your progress, Bob.
    51%? I wonder how they measure the 51% figure. I see kit planes that are supplied with ALL parts finished...the "builder" only does assembly. And then you have the "fast build" kits with sub-assemblies complete.
    If compared to these experimental kits wouldn't a T-Craft rebuild qualify for 51%? In a decent restoration the plane is completely disassembled, all parts cleaned, repaired, painted and THEN it's completely assembled again. Plus most restorations include fabrication of new wing spars and fuselage wood.
    Sounds like more than 51% to me. But the FAA may see it differently.
    Bob Gustafson
  • Bobdog
    replied
    I reserved the N number for my "new plane".:joy: It gets a little intersting here....My fuselage number is 8770. According to the FAA records, 8770 is alive and well in Florida. So I checked the records on both sides of my serial number, and all are still registered EXCEPT ser # 8772. As I recall the factory was often off by a couple of numbers, so I have every reason to belive that my fuselage probably started life as ser # 8772. The N number, N96472, originally assigned to 8772 was available so I reserved it. I wish I would have done this a few months ago, so I could have celibrated her (plane still unnamed) 60th birthday!
    Thank you all for for your input,.....I'll go with the regular experimental.
    Bob
  • M Towsley
    replied
    Talk to the Feds at AFS610, 1-405-954-6400, or if you're not inclined to do that talk to the folks at EAA. They will tell you what you can do. Experimental/Amateur built I am not sure. I do know if you change say an Ercoupe, that was under 1320, to a higher gross it can never go back to LSA.
  • Vasey fan
    replied
    In experimental-amatuer built, doesn't the builder have the option of changing the limitations? If so, I would think you could change engines or gross weight, etc, at a later date to take advantage of the LSA rule.
    I believe the restriction in the rule was meant to keep folks from STCing a lesser gross to squeak in under the weight. The C-120/140 folks are a little upset over it.
  • Swick-T N7010S
    replied
    How are you going to meet the 51% rule? I always though that you can not rebuild a certified airplane and register it as experimental unless you can prove that you build or modified more the 51%. The Swick Clip wing conversion qualifies as a homebuild but ther are lots of mods to the factory airframe.
  • murphy
    replied
    I have a question for the group can you restore a Taylorcraft (F21A) add a larger engine (0320) and call it an experimental? How does all that work, do the Feds allow anyone to build a kit that resembles a Taylorcraft or is there a percentage you must change the airplane?
  • DanBrown
    replied
    Is it legal to register a homebuilt experimental t-craft right at 1320 to get some extra gross weight and still be able to fly it under LSA rules?
  • M Towsley
    replied
    JH,
    Don't forget, if you use the higher gross weight (over 1,320), you won't be able to fly it as an LSA if and when the time comes! You can't reduce it later and be legal.
  • jgerard
    replied
    Definitely go for amateur built experimental.
  • N96337
    replied
    Good for you Bobdog. I plan on just experimental/homebuilt. I don't really see the big benefit in LSA for me... I'm sure someday it could be, but I'd rather be able to use the higher gross weight if I want to.
    I'll be really interested in your progress, please keep us informed!!
    JH
  • Bobdog
    replied
    Actually, there was a data plate and log books included in the "kit", but they were not the correct ones for my fuselage. I feel that it is deceptive to build a plane around a data plate, so I'll register my plane as a homebuilt.
