Re: A-65 Engine noise
Hi Ron, I noticed that with the valve train too.
Always remember it as a click not thump, could be a memory problem.
These are probably dumb questions, cam bearing to cam have good clearances? wonder if you get the same noise if while turning prop you pull it forward (or push it backward) so the crank is in a constant thrust position? maybe the overcenter impulse of torque is bumping crank against thrust surface?
I don't find mine noisy. But wife also says I can't hear. Maybe I am getting a double benefit!
Dave.
Originally posted by Ron Babos
View Post
Dave.
