I’m trying to determine what my options are with respect to my aileron spar. The two pictures show what I believe is a bond failure starting from somewhere underneath each plywood doubler. 43.13, para 1-44 says “cracked spars may be repaired by bonding plates of spruce or plywood of sufficient thickness… . both sides of spar. As shown in Figure 1-10”. Figure 1-10 shows the spar sandwiched between two plates. The illustration also contains the phrase “No fittings within these limits” and is referring to the length of the reinforcing plate. I’m glumly interpreting that as meaning the use of doublers in this case won’t fly (no pun intended). I don’t immediately see a work-around in this chapter.
Am I going to have to build a new spar or does anyone know of a way to repair it? - Mike
