My Taylorcraft just went through annual with no problems, but the tach has started sticking at full throttle. This happened once before years ago and I had it rebuilt.
The more often and longer that it runs, the less it sticks. Soooooooo, is this definitely a problem with the tach (or cable), or is it possibly a crud buildup situation. Is there a good (simple) way to clean up the tach and cable to see if this is the issue? I'm guessing WD40 is not the solution.....maybe Marvel Mystery Oil?
Vincent
Vincent
