Can anybody offer some advice please?
My T-Cart has just had some serious engine work following compressions of 76, 76, 64 and 8. (Yes, eight).
New pistons, rings and valves and the engine test was today. It performed fine on the ground and after some long run-ups I took to the air. It performed fine for the first 20 minutes and I out it away in the hangar and went back to work.
An hour later I decided to do some more flying. Outside air temps here in the UK are 33 degrees at the moment. Power checks proved fine. On departure there was full power for about 10 seconds. After 10 seconds the max power went from 2100 rpm to a "hunting" 1700 to 1800. I had just become airborne and that was my max power for the whole circuit. I couldn't climb and completed the circuit at 100 ft.
After landing I stopped and applied the park brake. Once again, full power was achieveable for about 10 seconds before the 2100 rpm dropped toabout 1800 and dipped to 1700 intermittently.
After an EFATO 2 years ago at 100 feet I am naturally very un-nerved by today's experience and have to admit it has shaken me somewhat.
Speaking with Rob he suggested I mentioned that I have Millenium cylinders as this might have some bearing on the issue.
Someone else has suggested that it sounds like I have a fuel flow issue of some sort.
Any help gratefully received.
J
J
