Hmm....
I stripped the LH wing last night and stepped back to look at the two stripped wings stacked against each other. What the H_ _ _ ! The RH wing has 13 ribs and the LH 15. I noticed the 15-rib wing also has laminated spars. Is this a wing off a later craft? It still has the built-up aluminum ribs as does the RH. Excepting the issue descrbed below, and short of the dissapointment of not having originality or symmetry, are there any otherissues with proceeding to recover this wing?
Perhaps something even more disconcerting was the fact that this wing has the plywood spar doublers at the wing root attach fitting "inlayed" into the front spar. Inlayed may not be the proper term here. Picture the spar thickness narrowed via a planer on both front and back surfaces for about a half inch past the doubler length...then blending into it's full thickness on a nice radius. Makes me wonder if this has any relevance on Bill Berle's issues on the overall width variations that prompted the lengthy Harer STC post (spar/doubler) a while back.
What do I have in this wing?
