Empty Weight Of BC12D
  • Empty Weight Of BC12D
    Just for fun I wanted to do a poll on Empty Weights of everybodys BC12D. We can repeat for the pre-wars, but in order to get apples to apples just BC12D's on this one. C85's should be the same or nearly so.....unless If you have electrics. I just thought this would be fun. I'm at 820lbs. with C85-8 and 2 wing tanks.
    36
    Less Than 750lbs
    16.67%
    6
    750 to 800 lbs
    30.56%
    11
    800 to 850 lbs
    36.11%
    13
    Over 850 lbs
    16.67%
    6
    Re: Empty Weight Of BC12D
    Howdy Dano T,
    I think that I have already screwed up!!! N39203 '45 BC12-D Mod 19(Harer Conversion) C85-12 w/radio & transp w/encoder 922 lbs.
    Best Regards
    paul patterson
    Edmond, Ok
    N39203 Model 19 class of '45
    TF#509 EAA#720630
      Mine is 778 with wing tanks , metal prop and no wheel pants .
        I've got one from June 20,1946 (8 days after mine was manufactured) that's signed by W.H. Ross, showing mine at 752#, and EWCG at 19.2". I've got one from later (date too faded to read) from when they installed the C85-12 and McCauley metal prop, that's showing it at 781.5 (says it gained 18# with the conversion) Then I did one in '86 and came up with 868# with 24 gallons of fuel and full oil, and CG @ 14.62.
        JH
          N43433 with two wing tanks has empty weight of 759 lbs per weight and balance a few years old.
          Jerry in NC
          TF# 114
          Prior BC12-D's
          N43433
          N95823
          N44024
            Should have one poll each for BC12-D with 65 HP, one for BC12-D for non electric 85 HP and one for full electric 85HP
            Frank
              Several years ago,C85,ext baggage,skylight,wing tanks,no electrics...801 pounds.
              Jim
              Jim Hartley
              Palmer,Alaska
              BC12-D 39966
                46 bc12d c90-8 ext baggage skylight two wing tanks and 1500 lb gross wt inc, 830lb
                Lance Wasilla AK
                  My 46 BC12D-1 "Ace" with 1 wing tank, wood prop empty weight at 730 lbs.
                    46 bc12d C-65 787# no fuel, wood prop.
                    Robbie
                    TF#832
                    N44338
                    "46" BC12D
                    Fond du lac WI
                      Just did weight and balance on c-fggz.No fuel on board with o-200 starter large oil tank and remote oil filter with full oil .Battery wood prop sky light two wing tank empty.Weight 865lbs.Left wheel 395 right 403 tail 67.
