Gas hose for my DC-65, (L-2)
  • Gas hose for my DC-65, (L-2)
    I'm doing the annual on my DC-65 and want to install a new gas hose from the gascolator to the carburetor. The present one looks like it was installed sometime in January of 1942. The old L-2 manual calls it OA-19h, which doesnt mean much.
    I'm not familiar with all the new hose numbers, can someone please tell me what to order from Wicks or Aircraft Spruce?
    Chet Peek
    Re: Gas hose for my DC-65, (L-2)
    If it has hose clamps at each end, MIL-H-6000 will work fine. If it has AN fittings on each end, Aeroquip 303 or Stratoflex equivilent. I probably have what you need here Chet if you want to come by.
      An old bit of info that I think came from Forrest several years ago thats nailed up under Technical Resources at the web site:
      Early Taylorcraft airplanes used Automotive type gas and oil fittings
      There is nothing wrong with this original equipment replacement, its what the planes were certified with.
      Some folks have done a transition to "aircraft" fittings and that is always causing problems matching replacement parts.
      Once source for aviation and automotive hoses is:
      Specialty Hose Aerospace, 7802 Freedom Ave NW, N. Canton, Ohio 44720 ph# 1-800-362-6533
      For what its worth.
      bob.
