Recommended Mods
  • Recommended Mods
    GASCOLATOR ACCESS - Awhile back… somebody mentioned how difficult it is to drain fuel from the gascolator. I agree. Usually end up with an armpit dose of aviation cologne. Here is a couple photos of the access door on my father-in-law’s BC-65. Sure is a nice feature.
    Lets hear fom others on recommended mods.
    barnstmr@aol.com
    Re: Recommended Mods
    I use a long sampling screwdriver from the bottom, cut hole in cowl. or the other ship has a trunk latch fastener system real easy to open and reach in with sample cup...
    taylorcraft@neo.rr.com
      I just open the top half of the cowl and reach down there with my long arms and get a sample. Use a standard sample screwdriver, reach down below the gascolator and push up on the valve. No drips on me.
      Of course, I have the closed cowl. Looks like a nice setup for the open cowl.
      David and Judy
      TF# 651
      Butterfly Fun Lines
      1941 BF12-65
      N36468
      Grasshopper Fun Lines
      1988 Hatz CB-1
      N83LW
        I mounted the Curtis drain valve on a 45 degree AN fitting screwed into the gascolator, so you can reach in there with your screwdriver sample tube from under the cowling, with no holes, no doors, etc. Works great, no moving parts, all airplane quality hardware.
