Re: C85 Hiccup or Sleep depravation?
Ram air works with an open direct feed to the carb, ala racing ships, Mooney 201 ( ramair) is a good example, screen or filter blocks this effect quite a bit, the plate does not really degrade the system taht much.
That SB hits the nail on the head, then we go back to original training, clear her out more often in the pattern and descending. That addition of power when needed should Always be a two or three stage , slightly open , back; more open; back and then power all in as needed. It is a good habit, the mixture change on the Stromberg is correct. All other I see is good advise. YES check for intake leaks, spray a little starting fluid around the tubes ( gently) with help & a fire extinguisher handy if she speeds up you got one, check for staining around the elbow to cyl.
Kelli-Belle needs walked , I need to hook up the back blade on the tractor. The transfer of infor to the CD's works great! Bob will be updating the site with current events. Sun-n-Fun is close by. the factory is doing stuff, all's right in the World... bye
