The martin folks had an approval to use the wires on fabricated ribs for the Piper rib & the T craft rib. BUT I do not recommend it. You have to drill a hole & it always seems to crack.
Then THINK about it a moment, The stitching carrys the loads to the other side of the rib like it was DESIGNED to do...... the wires keep the loads on the same side. IF the stamped rib can be made to not cut the stitching cord then it COULD be used...... MAY it be used is the question.
Sooooo I stitch where stitching was used and use "Taylorcraft wire" where it was used.... I am probably not going over to the office to get the "approved" data for all this today, probably tomorrow IF I survive "wing nite"
