Why is my tail fin bolted and welded
  • Why is my tail fin bolted and welded
    Why is the tail fin on my 45 BC12D bolted and welded? Does it have to be welded? I need to remove the fin for repair, do I have to weld it when i put it back?
    As a side note. Does anyone have a serviceable c-85 to which i can apply the 100 hp STC? I will be in the market for one soon.
    Re: Why is my tail fin bolted and welded
    The vertical stabalizer should NOT be welded to the fuslage.
      Affirm. Not welded. Un-weld it, find out why some plonker welded it, fix that, then bolt it back on.
      I know that sounds easy....but it should not be welded.
        All
        Thanks, I will look into the whole thing and be sure that it is right before proceeding. It was very nicely welded too.
        Jim
          I suppose you could just leave it as is?
            If it flew straight before and there is no damage then it probably won't hurt to leave it as is but if it ever needs to be repaired for any reason later it will make it much harder to do. IMHO I would fix it the correct way while it is all apart.
              Originally posted by Sloanlow
              All
              Jim
              If some fellow had the choice of welding a 5/8" tube or installing 3/16" bolt I am guessing he would choose the bolt. So there might be some underlying damage that caused him to weld it together. Maybe there is a log entry or 337 describing the work? Dave.
                My tail section seems to have been repaired by "T A/C MFG co Rebuild". I looking at he logs but do not find this. Evidence is in metal tags welded to the frame. The logical solution is this.
                It was welded during the rebuild. During a subsequent rebuild the 3/16 drilled bolt was incorrectly installed with a self locking nut. Although a nut and bolt belong there, its not this nut and bolt. Since I have all the resources available to repair this , I think I will take this apart and inspect it then put it back right.
                Still sorting this one out.
                Jim
                  what is the ser# of your ship. there were two big windstorms that damaged a lot of ships prior to completion. They then were repaired and tagged as described. Subsequent recovers had someone do the weld job that part was not done at the factory.
                    Tribe
                    The serial number is 6670 and the tail number is 43011.
                      That ship was test flown by Al Barber, my father on Dec 28th, 1945. Does that show as date of manufacture on paper work or the data plate?
                        The date of MFG is 12/26/45
                        Jim NC43011
