I have started pulling the fabric off my plane and will soon be yanking the engine back off it and storing it(25hrs SMOH). I have read the continental instruction letter about prepping the engine for storage. I plan on using the dehydrator plugs and fogging the cylinders. I was going to drain the sump and store the engine(everything FWFD) up on its nose in an engine building stand vertically in a heated shop. I see Poly-fiber sells an engine storage oil. Any other recommendations?
I need some good elevators, especially the left one with trim tab. Really need a trim tab. Wait till ya see whats left. Where can a guy get some of that C-channel rib material for the horizontal stab? What about installing tube liners in the lower longerons back at the tail post like the supercubs? I have to replace about 2' of both lower longerons at the tail.
Pics to follow soon, you're going to love this!!
Any idea what fuse mods must be done to comply with the bc12d-85/harer STC. is it just wing mods? Not the model 19/F19 just the 1280 GW, C85-8 short mount upgrade. I may not get a bigger engine for a while, but would like to have the fuse modified as needed before recovering it. Gussets at the wing attach fittings maybe?
Jason
N43643
Jason
N43643
