fuel consumption measured
  • fuel consumption measured
    Very quiet afternoon so I went out to check fuel consumption on my C85. (Hey, test engineering is in my blood, I can't help it.) Three minute taxi and quick runup. Reset stopwatch. Cruise at 2000 rpm @ 1500 ft. for 58 minutes including coming down final really low and slowing at last few seconds. Touch down and brake 58 minutes, taxi back to fuel pump, 2 minutes. Fuel filled to bottom of tank filler both times: 3.68 gallons 100LL. Compute for 60 minutes, no compensation for 5 minutes taxi @ 700 3.807 gal. Truth is probably somewhere between 3.7 and 3.8, say 3.75, what with the 5 minute taxi and run up.
    With 24 gal comes to 6.4 hours. Was getting 83 (78/88) statute at that setting GPS two directions today. Comes to 531 miles, no reserves. Hmmm veeerrry interesting. I would have thought over 4 what with the larger jets and venturi that the 85 carb has. Oh, density altitude was 1600 at 100 ft, so say about 3000 where I was cruising. Any opinions: on a cooler day would I have done better or worse. How much? Mixture is fixed rich.
    Darryl
    PS almost forgot. Standing there almost dark after flying and hear this awful loud screeching scraping noise and look around hangar just as a Cessna 310 is grinding to a stop with the gear up. No one hurt. Really pretty plane. What a shame. Probably a write off. Sad. I've pulled three out of the dirt or mud in the last few years, I left it in hands of the fire department, ect. this time.
    Re: fuel consumption measured
    DARRYL,
    I also have a C-85 and feel it runs rich. At 2000 that is about the same as I indicate or maybe I am closer to 80 mph, but at 4000' density. I don't have many hrs on it but the fellow I bought it from said at 2000 to 2150 it runs about 4 gal / hr. Would be nice if we could lean it out.
    Opinion on the colder, denser air is you would get more hp from the denser air resulting in a leaner mixture and more lift so it would be a benifit since we can't lean out carbs out. Should result in a lower gal burn at same airspeed or faster or both.
    Les
      Darryl,
      Recently calculated my fuel burn over the last year (just divided the total quantity of fuel bought by the tacho hours in the last 12 months) and got an average burn of 15.11 Litres per tacho hour. Total time in the last year was around 80 hours. Can't remember the conversion from litres to US gallons off the top of my head but I guess it's on the web or a conversion chart somewhere.
      Andy.
      TF#405
      G-BRIH
      NC43762
          You guy cruise at 2000 RPM's with a C-85? I thought it was 2350 to 2400 Rpm cruise on a C-85.
            That would explain why I can't get 4gph. I run 2350-2450 @ 5-5.5 gph.
            Then again, it's dragging a big aluminum C-140 behind it too.
              The cruise rpm will depend on the prop you have. I tend to cruise at 2150 - 2200 and get 95mph using a 71 x 43 McCauley prop, but I've flown 65 hp Taylorcrafts which will cruise faster at lower rpm because they have a cruise prop.
              TF#405
              G-BRIH
              NC43762
                Originally posted by AndyDuke
                Darryl,
                Andy.
                I like this conversion
                15.11 liter = 0.0527577 hogshead [UK]
                  Ever tried a hogshead of mead - lovely!! warms the cockles of yer heart.
                  TF#405
                  G-BRIH
                  NC43762
                    ...and the heart of yer cockles, I'm sure.
