My A65 when backing off the throttle on down wind gets rough between 2000 and about 1600 rpm then smooths out at 1500 down. The cylinders are all 74 or better on pressure and I've changed the rubber on the intake tract. I thought maybe a gauge might give a clue on which one is going out, planes are tougth to pull a plug wire or to feel which header pipe is cool. I've tried to crack the primer to see if it's a lean condition but no change, rotating plugs(color is even on them) and L R both on the mags is normal and the cam looks good. Think a CHT might help in the hunt?
Bill
Bill
let us know what you find.
