I bought my Taylorcraft project, and it's been sitting idle since 2013. At least according to the logs, last entry was annual inspection in 2013. Now it sits with badly damaged left wing, lower empennage, and a left landing gear that doesn't match. I suspect that the left bungies gave way, on landing. At the time of last annual, the right side was repaired, and new bungies installed. Why they didn't replace all four is beyond me. (I would guess that the owner at that time wished they had)
Anyway. I had my local A&P/IA come by to have a looksee, and give his opinion on which way I should proceed. After looking at what I have, and concurring on my use of fuselage #2 to build a jig to repair fuselage #1, and also using #2 to replace #1, to get in the air quicker. he asked what happened to it. I told him that I had no clue, but based upon the evidence on hand, I would say left landing gear bungie broke. That was a week ago. Today, I decided to look up NTSB reports for the time frame between last annual, and following year. What I found is that the left landing gear folded like a bad hand, causing an off runway excursion, and left wing sustained broken spars, wing struts damaged, along with lower empennage being damaged. So, my suspicions were correct. (not that it really matters, I still have to fix it) But just a bit of confirmation as to the history of the airplane.
