cowl latch
  • cowl latch
    Firstly hope everyone is keeping well in these odd times.
    Does anyone know if the cowl latch as per the picture is still available from anywhere?
    Our Taylorcraft BC12D restoration is proving to be difficult as everything we look at has issues.
    Also fuel primer - We have an essex primer but it does not fit the panel - Anyone any idea what the original primer was? (i assume Essex primers have been used since)
    As always thanks in advance...
    Not sure if these would work. https://www.mcmaster.com/latches/dra...aw-latches-10/
      3Dreaming, what is your address? You can PM me. I've dealt with Rob Lees over there. The price will be right. I have one in my hand. Do you need both pieces? Alaska's pretty close, over the Pole! Dick Smith
      Dick Smith N5207M TF#159
        It's Tayloukuk that is looking for the latch.
          Thnx for the correction. Will send him a PM.
            Thanks Dick
              Ian, I've got your address info, will get latch headed your way. Dick
                Many thanks Dick
                Much appreciated BR Ian
                  I also need four latches
                  Thanks
                  -- Silvano
