OVHL of Big tach?
  • OVHL of Big tach?
    Well, I have had this BF-50 project for about 2 months. Plan of attack is Panel forward. Franklin pullled and disassembled - crank in to engine shop.
    Instrument panel pulled today - so where do I send the big tach for checkout and overhaul. Thanks.
    Franklin Power
    SN1193, NC22246
    Re: OVHL of Big tach?
    Tom,
    I sent mine to Keystone Instruments in Lockhaven, PA a few years ago. They did a real nice job on it, but be prepared to wait a few months...
    Good luck,
    NC29624
    1940 BC65
      Howdy Tom,
      You might also try Rudy's Instrument Repair in, of all places, Rudy, AR. They did a Turn & bank for me and did a fine job. Quick turn around and about as reasonable as anyone.
      Best Regards
      paul patterson
      Edmond, Ok
      N39203 Model 19 class of '45
      TF#509 EAA#720630
        I vote for Keystone in Lock Haven, PA. They have done a lot of instrument work for me over the years, always top notch.
        Ray
          My experience is solely with Keystone. Did a great job.
            Instrument Markings
            I am ready to send airspeed indicator out to Keystone. I have the original '39 instrument panel plate which carries text stating max airspeed. Do I need to have my airspeed indicator carry markings as to max airspeed of 131mph?
            Similiar question as to oil pressure temps, oil pressure, and max rpms on the SW big tach tied to the Franklin limits?
            Thanks in advance for all of the collective wisdom.
            Franklin Power
            SN1193, NC22246
              Tom,
              I didn't specify when I sent the big tach to Keystone that they mark it with oil temp/pressure limits. At my next annual, I was told to place some stick-on decals on the face of the glass.
              I would have them mark the gauge. If I had asked for them to do that while they were lithographing the face, it would have looked better.
              NC29624
              1940 BC65
                I ran the traps on this today with the local FSDO regarding required markings. I was told the the original type certificate is the bible. If it says that the instruments must be marked, they must be marked. If the type certificate does not requuire markings, they do not have to be marked.
                I need to confirm in writing from the FSDO, but that certainly is in-line with the original instruments that came with my project.
                Franklin Power
                SN1193, NC22246
