Fuel float
  • Fuel float
    I am interested in getting a new float for my 1941 BC12. Can anyone help?
    The one I have has been droped and some of the coating on the float is missing. Perhaps it could be recoated. Does anyone have information on what material to use to recoat the float?
    Re: Fuel float
    Howdy Ron,
    A new float and stem are an easy fix. A major sportng goods store will have a solid cork float(don't use one that is composed of cork pieces pressed and glued together!) Then go to your local hardware store and get a piece of piano wire-stainless or brass and a small can of Spar marine varnish. Build a new rod(or use your old one) and DIP the new cork in the varnish and let it dry. I recommend at lease two coats.
    Somewhere on this forum this was discussed but time and age won't let me remember when.
    Good luck
    Best Regards
    paul patterson
    Edmond, Ok
    N39203 Model 19 class of '45
    TF#509 EAA#720630
      Re: Fuel float
      Paul,
      Please let me know where you can get stainless steel music/piano wire. The only place who carries music wire is the local hobby store, and it is not stainless. The longest length of any wire I can find .093 (3/32") is ten inches long in stainless. I need an approximately twenty inch long piece. Also, my float looks like a synthetic material (black). Any idea where that came from? Thanks!
        Re: Fuel float
        I've tried two coating that I've proven do NOT work. One was "Hot Fuel-Proof Dope" It's not as fuel-proof as you might imagine.
        The other was JB-Weld which is a two part epoxy. I thought that stuff would stand up to anything. It lasted about a year. But it started to detach itself from the cork to form a small bubble. I then peeled it off of the cork in big pieces. None got in the fuel. But I was dissapointed.
        Since then (about 4 years ago) I've used no coating at all.
        Tim
        Tim Hicks
        N96872
          Re: Fuel float
          Hot Fuel Dope from a hobby shop has worked well for me.
          Jerry in NC
          TF# 114
          Prior BC12-D's
          N43433
          N95823
          N44024
            Re: Fuel float
            For stainless wire, try your local ham-radio sources...those long, thin whip aerials work just fine!
              Re: Fuel float
              A frriend of mine made me up a new float for me, using a brass float from an automotive carburetor. He soldered a piece of stainless wire through the center. There is no cork and no coatings. Should last forever. Very easy to check on a pre-flight, just shake it next to your ear. If there is any fuel splashing around in it, then it has sprung a leak and must be repaired. If there is no fuel inside it, then you're good to go.
              PS: Any hobby shop that doesn't have music wire ain't no hobby shop
                Re: Fuel float
                I found stainless steel welding rod that was just the right size (3/32" I think) at the local Arcet welding shop. Also, a hollow brass float is indeed the ticket.
                  Re: Fuel float
                  Howdy Ron,
                  Try Aircraft Central Equipment(ACE) They should have what you need. I still recommend 2 coats of Spar marine Varnish. I always check my float when I fuel my acft.
                  Best Regards
                  paul patterson
                  Edmond, Ok
                  TF#509 EAA#720630
                    Re: Fuel float
                    I too used stainless welding rod to make a new rod for my float
                    Jason
                    N43643
                    Jason
                    Former BC12D & F19 owner
                    TF#689
                    TOC
                      Re: Fuel float
                      I'm not that knowledgeable about welding to know I could use the stainless welding rod. I saw it advertised in the right size, but thought it had only one use....welding. I took Rob's advice and went by the local radio shop and got a stainless antenna. Should work fine. Be aware most hobby shop music wire is NOT stainless, just regular carbon steel and will rust fairly quickly. Any thoughts on what kind of float I have? It looks synthetic and colored a greyish to black. Thanks.
                        Re: Fuel float
                        Paul Patterson,
                        Do you have info for Aircraft Central Equipment? Couldn't locate them....
                          Re: Fuel float
                          Howdy Marty,
                          Look in the white pages under ACE.
                          Almost forgot, you can also use brass but be sure it is BRASS and not the coated low grade carbon steel.
                          Best Regards
                          paul patterson
                          Edmond, Ok
                          TF#509 EAA#720630
                            Re: Fuel float
                            NAPA has the SS steel wire(welding rod).
