Does anyone have any information about doing a thrust-line conversion on a T-Craft, specifically an F19?
I know that there are many being done on the local PA18's and PA12's through STC, but wasn't sure if anything was available for the F19.
I also understand the F19 could benefit from this conversion more than the BC12D, as the thrust line is different. Is that true or hearsay, to anybody's knowledge? I'm helping rebuild a PA12 this was done to, and am very interested in it, as I could recoup some of the speed lost through modifications.
I know there are several jerry-rigged ones being done, but haven't talked to anyone with personal experience so far. Unless the entire cowl is rebuilt planes with the conversion are easy to spot as the uplift on the engine requires a strip be added to the side and bottom of the cowl to cover the gap.
Kathy
Kathy
, nice pics on your website man!) a plane ticket and I'll come out and show you how to properly set them up. They work fine when maintained and adjusted properly. My breaks are strong enough to lock up and skid 8.50's, and can hold a full power run-up easily. for more info on shin brakes use the search function of this forum.
