Are there any other exhaust systems STC'd .\? Like a Cessna 120?
Exhaust
There is an STC for the Luscombe dual exhaust, it is a pair of Y pipes...and you have to move the gascolator on a short engine mount airplane. Then cut a second hole in the cowl for the outlet. The cessna 150 is also a common swap if you need heat. I put on Aeronca Hanlon Wilson mufflers, with the cessna and Aeronca exhaust you will have to install blisters on the cowling to clear the mufflers. If you dont have a mechanic familiar with these mods, you may want to find one. this is not a cessna or piper so you have to approach it with a different mentality since there is no factory support and limited aftermarket options. Good luck, TimN29787
