It's a technical rant? Either way I would like to stich mine but I know they're stamped and looking at them ribs... they'z a little raspy. Can a guy use chafe tape on them ?
I might guess that you can use small rubber channel glued with silicone RTV to the edge of the stamped ribs to prevent the stitching cord from cutting.
That being said, why would you want to stitch a wing with stamped ribs? The "Martin-Wire" or Taylorcraft wire clip is a lot faster and easier.
You can now get the t-craft wire from ACS but I don't like it because it leaves ugly wire marks anywhere their is an oversized hole in one of the ribs.As for protecting your cord from the sharp edge of the rib,use chaffing tape,just let it over hang on the sharp side.Depending on the width of your tape you my have to use to wide down your ribs to cover the entire width of the rib.
Thanks guys; I'll be sure and photo document this part of the job for reference,specificly the rib fastener segments. Stay tuned its still some weeks away. Brad
