Carburetor air intake manifold
    Re: Carburetor air intake manifold
    I'll have to look to be sure about the prop, I'll get back to you tonight.
      Larry
      When you mention the certified 75 modification per factory specifications, could you give me a reference for that document, I know you have to modify the carb and rods but I would like to see the specifics.
      I have a McCauley CM74-45 metal prop. At full power I get about 2200 RPM(at altitude >5k drops to 2150) Now if my formula is right V(mph)= RPM*Pitch*.000947 this gives a theoretical max speed of 93.75 and I usually indicate low 90s. But if you reduce the pitch to 38 and 2300RPM doesn't this give 82.77mph as the theoretical max speed?
      Perhaps I have the formula and/or math wrong. I realize that reducing the pitch will give more RPM, and I sure would like to climb better than I do now, but I would like to keep the cruise speed at least in the low 90s.
      Thanks for all the great feed back
      Cheers
      Jim
        Here's a link
        Continental Engine Service Bulletin M47-16 (30 December, 1947, revised 9-25-68)
        This next link has a more readable image but older revision.
        Attached to this msg is the parts list.
          Jim, I remember formulas. That was the next row over from science. Right beside the shop class
          The numbers I quoted previously were from simple observation on my long cross country flights. I haven't measured the prop myself.
          There's always the tradeoff, climb vs cruise. That's why I like the 75 hp upgrade. Climb rate is increased by untwisting and shortening the prop. And by increasing RPM in cruise I have the speed in the 90's. Aggressive leaning keeps the fuel consumption down.
            I have found the perfect solution. I can get 1100lb of thrust out of this baby. So once I break free of the ground, point straight up for 30 seconds.......
            Richard Boyer
            N95791
            (STC is pending)
            Richard Boyer
            N95791
            Georgetown, TX
