Shoulder harnesses revisited
  • Shoulder harnesses revisited
    Not long ago there was some discussion about shoulder harnesses. Hooker's in particular. Following a couple of posts about them, I ordered a set from Hooker. They are now installed, an easy installation.
    The reason I've revitalized this thread is because last weekend an 11ACC Chief cracked up on takeoff. The wreck is now in a hangar at our airport, totalled, a very nice airplane once. It belonged to a prominent surgeon who also owns two Maules; this was his fun plane. There was some fuel problem or other that caused the engine to sputter and quit. He had just washed the plane so maybe some water in the fuel. The primer was not locked, so perhaps that was the problem. He hadn't flown it all winter, it was stored in a barn, so maybe a fuel vent was plugged, or birds built a home in his carb. His choice of landing spots also leaves a lot to be desired, but it is too soon in the investigation to be second guessing him. And he isn't talking because his jaw hit the instrument panel, leaving a hole in the panel, and is now wired together. His head is bandaged, and both legs are broken. His lung collapsed when his chest contacted the yoke suddenly. His right arm is immobile. He's a brain surgeon now in real trouble. This all begs the question: Was he wearing a shoulder harness? No! Very wealthy, multiple planes, lots of expensive real estate, and he hadn't had harnesses installed. These little planes are so docile, you can't really get hurt in one, right? In an much earlier post I told about my Piper J3 on lease back that spun in nearly killing a CFI and student. If you go to the NTSB site you'll be surprised by the high number of fatalities in docile little tube and fabric 4 bangers. I always fly scared, and I have thousands of hours in them. Why I waited until recently to install my harnesses I'll never know, because it's a no-brainer.
    Re: Shoulder harnesses revisited
    I was always extremely uncomfortable when I flew without them. I felt MUCH better once they were installed. This did not make me feel invincible, but was another weapon in my safety arsenal.
    I really think that flying without them is somewhat irresponsible.....
    Of course having said that, your face is your own if you wish to implant it in your panel. I have seen some of your faces........
    Richard Boyer
    N95791
    Richard Boyer
    N95791
    Georgetown, TX
      HEY! I resemble that face comment! I never worried about it when my plane was so ugly the Earth rejected it. I figured if I was crashing the "Ugly Factor" would stop the impact. Now that she is all pretty in her new paint job I think I will just put in the extra straps while the headlinner is out. Nice timing.
        I also have a set of Hooker belts and harness. I have installed these in each aircraft I have owned since they have been available.
        I have only had to experience them once, in an Ag Cub I was spraying with in Mississsippi many years ago. Caught a barbed wire fence and went up then immediatly straight down. Totaled the Cub, but at least walked away with only brusing. Have believed in them since.
        Lee
        Yellow Duck
          Hi Guy,
          All the Tayocraft only came with a lap belt CAR-3 certification requirement. All aircraft certificated under Part 23 are required to install shoulder harnesses. As some one who goes out and pickspilots out of aircraft after accidents I would strongly suggest you have your local mechanic install a set of shoulder harness.
          I have been of a couple of accidents that did have the shoulder harness installed, but incorrectly and the pilot hit the instrument panel. If you install them make sure and follow the manufactues procedures and check AC 43.13 2A as to where to attach and install the doublers.
          Stache
            I own a 1946 85hp Taylorcraft with lap belts only. I want to add the shoulder harnesses. Would someone give me the part # for the hooker harnesses you have been talking about? Do most of you use these or other brands? Thank you.
              Go to search and type in Hooker Harness. There are a lot of postings that discuss using them plus telephone numbers and part numbers. The installation is very easy if you don't mind cutting into your headliner. Mine is ceconite, so I cut out a piece and attached the harness in about 5 minutes.
                I have to do a little more with my belts. I have the military 3 incher on the bottom and I think they are fine, mostly because of the heavy duty construction and I believe the wide belt will do less damage to your lower body when you try to exit the hard way. They are very reasonably priced also, I suppose the engineering cost was absorbed years ago, probably by the government. Good deal, I say. When I bought the plane the shoulder harnesses were attached to the bar right behind the pilots sholders. I haven't changed them, but they make me really nervous, because while they are perfect for turbulence, in an accident they would no doubt seriously damage my spinal column. I think I'm going to move them to the high bar if the angle is correct and use a cable back to the triangulated tubing point for strength, or just go back to the triangulated point if the angles work out.
