The hub on a 65's tapered crank has no bushings to fit into the counterbore on the wood prop. Sensenich installation guide says nothing about this except that the driving force comes from static friction and the bushings on a flanged crank are not to drive the prop anyway. Am I correct in assuming that my prop can be used in this configuration without bushings, or should the prop bolts be bushed for the counterbore, or what?
Ed@BTV VT
TF 527
Ed@BTV VT
TF 527
