Question:
I read the Stitts pamphlet about airframe prep and I decided to do the sandblast/wash primer/epoxy primer process. I applied Aero Tech products as specified and the end result looked fine.....for about 5 years. The airframe has been indoors the entire time (although subject to South LA humidity) and rust is popping through the primer. I'm glad I have not gotten around to covering the thing because I would now have to start all over again. I did the wash primer thing because it was recommended for seaplanes, but the process has totally failed.
Any advice on a finishing procedure that will have a bit more longevity? I am resigned to the fact that I will have to sandblast again, but I will definitely not use the same method of painting again.
Thanks for any advice you can give.
