L-2M - need new fuel cap
    Re: L-2M - need new fuel cap
    Where do you get the die to stamp the tabs?[/QUOTE]
    I bought them from McMaster-Carr, give me 3 or 4 days and I should be able to find them, only used once, it like new condition, gary
      2 pieces of 5/8 wide .035 steel about 1.5" long and stamp with a harbor freight stamp set, align tabs with cap on tank, mark location, then braze on!
        Thanks, if you are able to find them I'm interested Gary.
          Got'em, along with an original throttle knob, some Boeing fastners, all the pieces including cups, original springs, the hardest part, the piece that you grab with your thumb= has the plate on it with two holes in it to capture the spring and cup, some of the parts are usable, even painted, others with make good pattersn or give you measurements to try and find them, just need an address, gary
            SteveR, while looking for the stamps I also found a cap with the tabs on and GAS and 6 GAL on the tabs but for some reason the vent tube has been cut off, but it woulkd still require a little braze job, you want that also, gary
              Gary,
              If Steve doesn't want the 6 GAL gas cap (without the vent tube) you just found, I'll take it.
              Peter
                Originally posted by Peterroy View Post
                Gary,
                Peter
                OK, Let's give Steve a few days to respond and go from there, also when i built up the L-2M, I made a new door and have the removed door latch and some other stuff, I lost my son in a car accident at about that time, so its hard looking thru that stuff, gary
                  Sorry to hear about your son. Tough, I know.
                    Thank you, PM sent, gary
                      Yep, I'd be glad to have them! I'll send you a PM.
