Checklist
  • Checklist
    So I have used the checkmate aviation check list and found them handy.
    They don't have a T craft list made but would custom print one or would use a cubs...
    but i have fun toys to use at work and debated making custom one..
    Any preferences on material it is made of.. I debated laser etch plastic stainless or aluminum
    Re: Checklist
    A paper checklist is quite good too.
      Re: Checklist
      Ok I have combined information from a cub type checklist to a full checkmates aviation list. some stuff seemed nice to have while some seemed redundant.. Having a friend begin his training now in a craft I am trying to help him along and this list is one of the things.
      Need some help I haven't found numbers yet
      Full throttle RPM?
      ROATE SPEED?
      Best angle Speed?
      Best Rate Speed?
      Cruise
      Economy? speed and rpm
      normal?speed and rpm
      maximum?seed and rpm
      Pattern
      Approach?
      Short final?
      I will publish the files here shortly let me know what you use and Ill try to incorporate
        Re: Checklist
        COCKPIT
        Radio / Intercom
        MAGS OFF
        Controls Free
        Flight control Wires
        LEFT SIDE
        Landing Gear Bolts
        Tires
        Fabric Wing and Side
        Wing Strut Attachments/ Tie Down
        Pitot Tube
        Aileron Hinges
        TAIL
        Trim Fins
        Flying Wires
        Rudder and Elevator Hinges
        Tail Wheel / Cables / Springs
        RIGHT SIDE
        Fabric Fueselage and Wing
        Door Secure
        Landing Gear Bolts
        Tires
        Aileron Hinges
        ENGINE & NOSE
        OIL is 3-4 Qts.
        Fuel Main and Wing Tanks
        Check Fuel Bowl for Water or Debris
        Cowling is Secure
        Intakes and Exhausts for Critters
        Prop Damage Free and Secure
        USEFUL SPECIFICATIONS
        Empty Weight
        Gross Weight
        Useful Load
        Rate of Climb at Gross 450
        Cruise Speed 73MPH
        Stall Speed 38
        Takeoff Run 370 ft
        Fuel Consumption 4.4 Gal/hr
        Fuel Capacity
        this is the list I have started is there anything somebody would like to see added or changed My hope is that I will present an open file that you can customize for personal use
          Re: Checklist
          portions of this were posted earlier it was found on an online blog i removed the personal information etc here is just a beginning please let me know if there are conflicts
          Before Entering the Aircraft:
          (1) Tie downs—Remove
          (2) Aileron Linkage Openings—Remove plastic plugs, (bird nests?)
          (3) Exhaust—Remove absorbent
          (4) Chocks—Remove
          (5) Pitot Tube—Check opening
          (6) Windshield—Clean
          (7) Oil—Check, three to four quarts, (leaks?)
          (8) Fuel Shut Off—On position, (leaks?)
          (9) Fuel—Drain, check for color (blue tint), contamination, and water
          (10) Fuel Tanks—Check for capacity, cowl 12 gallons and right wing 6 gallons (Note: Transfer fuel after 90 minutes of flight)
          (11) Controls—Remove seat belt lock
          (12) Ignition—Check off position (Note: Remove keys when not in use)
          (13) Control surfaces—Check for freedom of movement and security, (bird nests?)
          (14) Tires—Check for proper inflation, 20 – 30 pounds of pressure
          (15) Propeller—Check for nicks and security
          (16) Aircraft—Free of frost, ice, and snow
          (17) Cowling—Secure
          (18) Baggage—Secure, baggage capacity 50 pounds (Note: Baggage allowed only if within total weight limitations)
          After Entering Aircraft:
          (1) Doors—Close and secure
          (2) Windows—Close and secure
          (3) Seat Belts—Fasten
          (4) Required Documents—In order:
          a. Airworthiness Certificate
          b. Limitations
          c. Registration, Federal
          d. Registration, State of Iowa
          (5) Altimeter—Set at field elevation or AWOS
          (6) Tachometer Time—Record
          (7) Wrist Watch Time—Record or set
          (8) Timer Count Up Time—Begin
          (9) Density Altitude—Compute
          (10) Fuel--Compute
          (11) Weight and Balance—Compute
          a. Fuel in cowl tank—72 pounds
          b. Fuel in right wing tank—36 pounds
          c. Oil capacity—One gallon, 7.5 pounds
          d. Useful Load—447 pounds
          e. Total Fuel and Oil—115.5 pounds
          f. Remaining Useful Load—331.5 pounds
          g. Less Pilot—190 pounds
          h. Passenger—141.5 pounds
          i. Baggage—50 pounds, NOTE: Baggage allowed only if within total weight limitations
          (12) Radio, NAV / COM, Sporty’s JD-200—On
          (13) Inter-comm, Sigtronics Transcom II—On
          (14) GPS, Garmin 195 Map—On
          (15) Headsets, David Clark—On
          Starting the Engine:
          (1) Wheels—Chocked if solo
          (2) Switch—Off position
          (3) Brakes—Applied
          (4) Control Wheel—Full back
          (5) Throttle—Closed position or cracked 1/8 inch (Note: Closed is rearward position)
          (6) Carburetor Heat Control—Cold or forward
          (7) Fuel—On
          (8) Reserve—Off
          (9) Prime—Two times if engine is cold
          (10) Prop—Switch off, pull six blades
          (11) Contact—Ignition on both magnetos
          (12) Prop—Pull and step away fast
          (13) Oil Pressure—Up within 30 seconds at 30 pounds of pressure (range 10 – 40)
          (14) If engine fails to start, the above procedure varies
          Taxing:
          (1) Speed—Maximum of 800 r.p.m.
          (2) Visibility—Make “S” turns for maximum forward visibility
          (3) Braking—Minimum required
          (4) Elevator—Control wheel full back, neutral position if there is a tail wind
          (5) Ailerons—Position for quartering winds
          Take Off:
          (1) Oil Temperature--Warm, 120 degrees Fahrenheit
          (2) Carburetor Heat--Cold
          (3) Power--Full throttle
          (4) Trim--Nose down slightly
          (5) Elevator--Control wheel forward
          (6) Lift Off--55 mph
          Cross Wind Take Off:
          (1) Keep windward main gear securely on the runway with ailerons until a positive lift off speed has been attained
          (2) Maintain alignment with the runway with the rudder
          (3) After liftoff crab into the wind to maintain runway alignment and / or directional control
          Short Field Take Off:
          (1) Use all available runway
          (2) Raise tail as soon as possible
          (3) Climb at 65 m.p.h. until clear of obstacle
          Soft Field Take Off:
          (1) Raise the tail just off of surface
          (2) Maintain a climb attitude
          (3) Remain in ground effect after lift off before climb out
          (4) Airspeed—65-70 m.p.h. (66 or 67 ideal)
          Climb:
          (1) Airspeed—65 – 70 m.p.h. (66 or 67 ideal)
          (2) Power—Full throttle
          (3) Carburetor Heat—Cold
          Cruising:
          (1) Power—2,150 r.p.m.
          (2) Trim—Adjust
          (3) Airspeed—92 – 105 m.p.h.
          Let Down:
          (1) Power—As desired, in cold weather maintain 1,500 r.p.m.
          (2) Carburetor Heat—Full on
          (3) Airspeed—65 – 70 m.p.h. or as desired
          (4) Rate of Decent—300 – 500 f.p.m.
          Before Landing:
          (1) Carburetor Heat—Full on, always apply full heat before closing the throttle
          (2) Fuel--Check
          (3) Trim—Nose up two turns
          (4) Airspeed—Approach 60 m.p.h., gusting winds approach airspeed 70 m.p.h.
          Balked Landing:
          (1) Power—Full
          (2) Carburetor Heat—Cold
          (3) Trim—Nose down two turns
          Normal Landing:
          (1) Touchdown—Tail wheel first
          (2) Airspeed at Touchdown—45 m.p.h.
          (3) Landing Roll—Control wheel full back
          (4) Braking—Minimum required
          Cross Wind Landing:
          (1) To maintain alignment with the runway you may use: (a) the slip, (b) the crab, or (c) a combination of both
          (2) Keep the windward wing down and into the wind with lots of aileron control during the flare
          (3) Prior to touch down maintain alignment with the runway with necessary rudder control Keep windward wing sharply down and into the wind with the ailerons
          (4) Keep the windward main gear only securely on the runway with the ailerons
          (5) In severe wind conditions a wheel landing may be an option
          (6) Limit cross-wind landings to a 10 m.p.h. 90 degree cross wind
          (7) Continue to be vigilant until the aircraft has stopped
          Emergency Landing:
          (1) Check fuel, reserve tank on
          (2) Check for carburetor icing, apply full carburetor heat
          (3) Immediately establish best glide angle
          (4) Use trim, two turns of nose up
          (5) Maintain an air speed of 65 – 70 m.p.h.
          (6) Select a field into the wind
          (7) If row crops, land with the rows
          (8) Remain close to the field by circling if you have sufficient altitude
          (9) Aim for the far side of the field to give yourself a margin for error
          (10) Turn ignition off
          (11) Turn fuel off
          (12) Tighten your seat belts
          Short Field Landing:
          (1) Trim for slower than normal approach speed
          (2) Use a full stall, three-point landing
          (3) Braking, as necessary
          (4) May wish to turn upon roll out
          Soft Field Landing:
          (3) Use a power-on approach and touch down of about 1,500 r.p.m.
          Wheel Landing:
          (1) Do not use trim
          (2) Set power at 1,500 r.p.m.
          (3) Assume a slight nose down attitude
          (4) When wheels contact the surface immediately apply forward control wheel pressure
          (5) Maintain forward control wheel pressure until the tail wheel drops on its own
          (6) Then, maintain back control wheel pressure as in a normal three-point landing
          After Landing:
          (1) Control Wheel—Full back
          (4) Wing tank—Off position
          (5) Radio—Off
          (6) Inter-comm—Off
          (7) GPS Garmin 195 Map—Off
          Securing Aircraft:
          (1) Ignition—Off
          (2) Key—Remove from ignition
          (3) Fuel Shut Off—Off
          (4) Controls—Secured back with left-hand side seat belt or bungee cord around throttle base
          (5) Wheels—Chocked
          (6) Tie downs—Secure, tie to the strut and ring
          (7) Aileron Linkage Openings—Plugged with plastic
          (8) Exhaust—Plugged with absorbent
          (9) Tachometer Time—Recorded
          (10) Flight Time—Recorded
          (11) Stop Watch Timer—Recorded
          (12) Air Vents—Closed
          (13) Fuel Caps—Install rain proof fuel caps
          (14) Flight Plan—Closed
          Taylorcraft N39911 Specifications
          Aircraft:
          (1) Gross Weight—1,200 pounds
          (2) Take Off Run—640 feet, actual
          (3) Take Off Distance Over a 50 Foot Obstacle—1,280
          (4) Best Rate of Climb Speed—66-67 m.p.h.
          (5) Best Angle of Climb Speed—65 est.
          (6) Rate of Climb—500 feet per minute for the first three minutes at full power and gross weight
          (7) Service Ceiling—14,000 feet plus, actual test.
          (8) Absolute Ceiling—15,100 feet
          (9) Top Speed—130 m.p.h.
          (10) Cruising Speed—92 – 105 m.p.h.
          (11) Cruising Speed Optimum Altitude—3,000 feet?
          (12) Instructional Power Cruise Speed—85 m.p.h.
          (13) Fuel Consumption—4.2 – 4.25 g.p.h.
          (14) Cruising Range—389.62 miles, no reserve
          Note: When fuel gauge indicator (wire) rests on the fuel cap, 2.4 gallons (legal reserve) remains in the cowl (main) tank
          (15) Stalling Speed—45 m.p.h.
          (16) Landing Roll—640 feet, actual
          (17) Empty Weight—750 pounds
          (18) Useful Load—447 pounds
          (19) Payload—156.5, full fuel
          (20) Landing Roll Over 50 Foot Obstacle—1,280 feet?
          Power Plant:
          (1) Engine—Continental A 65-8, A.T.C. 205
          (2) Rated Horsepower and Speed—65 h.p. at 2,300 r.p.m.
          (3) Bore—3 7/8 inches
          (4) Stroke—3 5/8 inches
          (5) Displacement—171 cubic inches
          (6) Compression Ratio—6.3 – 1
          (7) Dry Weight—742.5 Pounds?
          (8) Oil Capacity—Four Quarts, 7.5 pounds
          (9) Propeller—Fixed pitch, diameter, 7443, reconditioned at 72 inches, with round tips, power prop, ACE balanced
          Fuel and Oil:
          (1) Fuel Capacity (U.S. gallons) standard—12 at –9
          (2) Fuel Capacity (U.S. gallons) reserve—6 at +24
          (3) Oil Capacity (quarts)—4 at –21
          (4) Fuel, Aviation Grade (minimum octane)—recommended 73, permissible 80 / 87, available 100 / 130 LL, auto fuel ok in an emergency
          (5) Fuel Rate—4.25 g.p.h.
          (6) Fuel Rate—Current best at 3.9 g.p.h.
          Baggage:
          (1) Maximum Baggage—50 pounds at +40
          (2) Baggage—Cubic feet, xxxxx
          Seating:
          (1) Two Seats—at +23
          Dimensions:
          (1) Wing Span—36 feet
          (2) Wing Area—Square feet, 183?
          (3) Wing Loading—Pounds per square foot, 6.557?
          (4) Length—21 feet, 9 inches
          (5) Height—78 inches
          (6) Power Loading—Pounds per horsepower—18.4615
          (7) Wing Chord—63 inches
          (8) Dihedral—One degree
          Landing Gear:
          (1) Wheel Base—6 Feet, 2 inches
          (2) Wheel Tread—Feet, xxxxx
          (3) Tire Pressure—Main 29, tail wheel none
          (4) Tires—6.00 x 6, 2 ply
          (5) Tail Wheel—6 x 200
          Magnetos—75 r.p.m. drop at 1,800 r.p.m.
          Carburetor—At 2,150, drop not less than 75 r.p.m., drop not more than 200 r.p.m., 100 r.p.m. drop at full throttle, 2,200 static r.p.m.
          Tachometer:
          (1) Red Line—2,300 r.p.m.
          (2) Cruising—2,150 r.p.m.
          (3) Maintain Altitude—1,500 r.p.m.
          (4) Idle—550-600 r.p.m. with carburetor heat off
          Oil:
          (1) Oil Change—Every 20 – 25 hours
          (2) Oil Temperature—120 - 175 degrees
          (3) Oil Pressure—Range 10 – 35 pounds, 30 is normal
          (4) Oil Temperature—Red line, 220 degrees Fahrenheit
          (5) Oil Temperature—Green Arc, 120 – 220 degrees Fahrenheit
          (6) Oil Temperature—Yellow Arc, 40 – 120 degrees Fahrenheit
          (7) Oil Brand and Weight—Phillips 66, X / C Aviation Multiviscosity Oil SAE 20W-50, Blue Container, One U.S. Quart
          Air Speeds:
          (1) Red Line—130 m.p.h.
          (2) Cruise—92 – 105 m.p.h.
          (3) Climb—66 – 67 m.p.h.
          (4) Glide—65 – 70 m.p.h.
          (5) Approach—60 m.p.h., gusting wind 70 m.p.h.
          (6) Stall—45 m.p.h.
          (7) Lift Off—50 – 55 m.p.h.
          (8) Maneuvering—90 m.p.h. or 1.7 X 45 = 76.5
