Wheel bearings for Scott 3200
  • Wheel bearings for Scott 3200
    The wheel bearings on my Scott 3200 are worn and should be replaced. I looked in the Spruce catalog and do not see them listed. Any suggestions on where I might find replacement bearings?
    Thanks.
    Peter
    Re: Wheel bearings for Scott 3200
    See if you have a Motion Industries in your area.
      If you need FAA-PMA'd parts page through this replacement parts list: http://www.airframesalaska.com/Alask...eel-s/1847.htm
      It's typically a Timken A4050 bearing and A4138 race. You might want to replace the grease seals as well as the exposed felt wears and can allow dirt and water to easily enter the hub.
      They recommend Exxon-Mobile SCH-100 grease for lubing the wheel assembly and bearings.
        Peter, Alaska bushwheel carries all of the replacement parts too.
          Thanks guys. I placed my order.
